use
Uses CRM (Critical Resource
Monitoring) to monitor link status
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
use critical-resource-monitoring
Parameters
use critical-resource-monitoring |
Uses CRM to monitor the status of a link. Selecting this option
determines the disposition of the route-map next hop via monitored critical
resources. Link monitoring is the function used to determine a potential
fail over to the secondary next hop. This option is enabled by
default. |
nx9500-6C8809(config-routing-policy-testpolicy)#use critical-resource-monitoring
